8~15W 箱子的选择,随便聊聊。 [复制链接]
查看: 11030|回复: 45
1。vonschweikert - VR-4SR Mk2
最后编辑迷糊
3。wilson watt / puppy 7
找一对自己满意的音箱实在难.所以偶自已DIY
如果你是,会怎么选?
我也是7了
一点 在 2006-11-18 10:56:23 发表的内容
我也是7了
富盛 在 2006-11-18 10:59:01 发表的内容
Aerial Acoustics Model 20T!!
SPECIFICATIONS
Frequency Response      27 Hz to 30 kHz ± 2 dB. -8 dB at 23 Hz and 40 kHz
Sensitivity                        90 dB at 2.83 Vrms and 1.0 meter on axis
Impedance                       4 Ω nominal, 2.8 Ω minimum, low reactance
Power Requirements        50 to 800 watts (8 Ω rating) recommended
Crossover                      300 Hz and 3.5 kHz at 24 dB per octave Linkwitz-Riley
Large independent networks on glass-epoxy PCBs
High-purity copper wiring with TeflonÆ insulation
Assembled 15.4 x 10.7 x 22.5" (390 x 272 x 572 mm)
29.1 x 12.6 x 22.5" (740 x 320 x 572 mm)
47.0 x 12.6 x 22.5" (1194 x 320 x 572 mm)
Weight Each 252 lbs (115 kg). 346 lbs (157 kg) packed
[upload=jpg]Upload/200611181185824879.jpg[/upload]
20 T的价格跟威信7比如何?
若价相近.我选富盛之20t.7仔动态好但高音较噪耳朵听音容易疲劳.20t高音为铝带声音晶莹些.相对7仔比较耐听
2。B&W 802D
