有那位朋友知到这是ATC什么箱,养眼啊! [复制链接]
查看: 4291|回复: 8
该用户帖子内容已被屏蔽
卖几十w的...
该用户帖子内容已被屏蔽
不知又得多少米啊
样子够吓人的
是电台版监(录音室)听箱吧- - - - - -
该用户帖子内容已被屏蔽
SCM300ASL Pro
SCM300ASL Pro
Based on the same mid and HF drivers, and the same amplifier block as the SCM200ASL Pro, the SCM300ASL employs larger 375mm bass drivers and a larger 300 litre enclosure to deliver even higher maximum volume (121dB/1m), with extended bass and increased transient headroom.
SPECIFICATIONS
SCM300ASL Pro
Drivers HF
  Mid
  LF
34mm
75mm
2 x 375mm
Amplitude Linearity ±2dB 50Hz - 12kHz
Cut-off Frequencies (-6dB free standing) 25Hz - 20kHz
Cut-off Frequencies (-6dB soffit mounted) 20Hz - 20kHz
Max Continuous
SPL @ 1 metre  121dB
Dispersion
  Horizontal
  Vertical
d
±80° Coherent
±10° Coherent
Amplifier Output:
Bass
Mid
High
275 + 275 Watts RMS
200 Watts RMS
100 Watts RMS
Overload Protection  Active FET Momentary Gain Reduction plus thermal tweeter protection
Input Impedance  >10k ohms
Input Sensitivity 2V
Crossover Frequency 380Hz - 3.5kHz
Input Connector Male XLR
Cabinet Dimensions (HxWxD) 884 x 925 x 460mm
Overall Weight 140kg
我也想知道。
