请问Denon DRA-697CI 用来做HIFI 功放合适么? [复制链接]
查看: 1766|回复: 0
HI,各位大虾您好,以下是Denon的产品描述.但这款产品的定位是AV,不知道是否适合来做HIFI系统的公房. 我的箱子是加拿大的Naunce,似乎比较难推,卖家跟我说要选100w X2左右的大功率机器. 我的CD用的是Combridge Audio的Azur系列的 DVD 540,国外评价似乎说CD播放很好,于是就买来做HIFI CD音源.不知道这样的搭配,用 Denon DRA-697CI 是否合适? 跟同价位的纯HIFI公房来比较,差在哪里呢? 谢谢各位老师...
Denon DRA-697CI Black Stereo Receiver - DRA697CIThe DRA-697CI receiver will shine as the core to your high end Hi-Fi stereo multi-room audio system. Equipped with many new features, it can handle almost any configuration combination. Its two source three zone capability allows you to run multiple sources to multiple areas at the same time with pure clean sound. Being 4 ohms stable, it can handle the most demanding speakers, yet deliver smooth fidelity. Custom integration is no problem either as this enhance receiver has all the connections an installer needs to integrate to third party control systems.
Features:
  • 100 watts x 2 channels
  • Signal Level Divided Construction (S.L.D.C.)
  • RS-232C control
  • Serial IR remote ports
  • Subwoofer output
  • +12 volt triggers
  • XM Radio Ready (Connect and Play antenna sold separately)
  • Dedicated iPod port for optional ASD-1R iDock
  • Upgradeable to HD Radio (model/price TBA)
Specifications:
  • Power Amplifier Section:
    • Rated Output: 100W + 100W (8 ohms, 20Hz - 20kHz, 0.08% THD)
    • Total harmonic distortion: 0.009% (-3dB at rated output, 8 ohms, 1 kHz)
    • Frequency response: 10Hz - 100kHz +0 dB, -3 dB (at 1W)
  • Preamplifier Section:
    • Input sensitivity/Impedance
    • Phono: 2.5mV/47kohms
    • CD, CD-R/Tape, DVD/VDP, VCR, V. AUX: 200mV/47kohms
    • Output level/Load impedance
    • Zone2, Zone3: 1.2V/47 kohms
    • RIAA deviation: +/- 0.5db(20Hz - 20kHz)
    • Tone control: Treble: +/-10 dB at 10kHz, Bass: +/- 10 dB at 100 Hz
  • FM Section:
    • Tuning frequency range: 87.5 - 107.9 MHz
    • Usable sensitivity: 1.4 礦(14.2 dBf)
    • S/N 50 dB sensitivity (礦 at 75 ohms)
    • Mono: 2.8 礦(20.2 dBf)
    • Stereo: 23 礦(38.5 dBf)
    • S/N ratio (A-weighted): Mono 80 dB, Stereo: 75 dB
    • Total harmonic distortion: Mono: 0.15%, Stereo: 0.3%
    • Capture ratio: 1.5 dB
    • AM suppression: 50 dB
    • Image rejection: 70 dB
    • Effective selectivity: 55 dB (+/- 400 kHz)
    • Frequency response: 30 Hz -15 kHz, +0.2, -1.5 dB
    • Stereo separation: 40 dB (1 kHz)
  • AM Section:
    • Tuning frequency range: 520-1710 kHz
    • Usable sensitivity: 18 礦
  • General:
    • Power supply: AC 120V, 60 Hz
    • Power consumption: 10.6A
Approximate Dimensions:
  • Width: 17.1"
  • Height: 5.8"
  • Depth: 16.4"
Approximate Weight:
  • Unit: 20.2 lbs
  • Shipping: 25 lbs
Downloadable (.pdf) Files:
Manufacturers Model Number: DRA-697CI
Denon Black Stereo Receiver
Model: DRA697CI
