纸膜油浸电容和现代薄膜电容的完美结合 [复制链接]
查看: 11097|回复: 36
V-Cap OIMP reference grade oil capacitor
The V-Cap OIMP series (Oil Impregnated Metalized Polypropylene) film capacitors are the result of an extensive research and development project by a team of world-renowned experts in electrical engineering, chemistry, materials science, and some of the top minds (and "ears") in the audio industry. These are the same experts who designed the award-winning TFTF (Teflon Film Tin Foil) series of V-Caps. The resulting series of proprietary materials and processes has produced what we believe is one of the most transparent and musical oil capacitors ever made.
Improved reliability and performance
Oil impregnated capacitors have long been coveted by audiophiles for use in power supplies, speaker crossovers, and various signal applications. The V-Cap engineering team has developed the V-Cap OIMP series to combine the smooth musicality of paper in oil designs with the transparency and superior electrical properties of modern film capacitors. Uncompromising sonic performance and long-term reliability has been achieved by utilizing a special proprietary metallized polypropylene film, chosen for it's exceptional sonic and physical qualities. Our metallized film is chemically ultra-stable which means you can expect more consistent performance over the prolonged life of your capacitors.
Optimum materials, perfectionist design criteria, and obsessive quality control...
Selecting the best film was just one of many stages in the design and refinement process that led to the V-Cap OIMP series. Transferring the unique Variable Stage Quadrant Dielectric? Winding technology to the OIMP series was a stunning development on its own, but even further progress was made by perfecting the actual oil impregnation process. This ensures the highest level of performance, reliability, and consistency from capacitor to capacitor.
Despite the higher expense, the V-Cap design team selected a premium grade solid brass cannister*, deemed to be sonically transparent and structurally superior to other materials tested. The container is hermetically sealed and employs custom made audio-grade diaphrams and end caps, virtually eliminating the possibility of mechanical and electrical failures. This means superior robustness, no leaks, low DF/ESR, and sonics that redefine the performance limit of oil capacitors. The design, materials and processes used to make the V-Cap OIMP series have been so precisely engineered, selected and executed that we boldly offer an unprecedented * LIFETIME WARRANTY to the original purchaser. See below for details.
During the beta testing process (completed November of 2004), a select group of audiophiles and equipment manufacturers/modders were given these capacitors without any knowledge of their internal construction, or the 搕ype?of capacitor they were. The beta testers only knew the voltage rating and the value, in order to get the most unbiased evaluations possible. To read these beta testers' comments and also a very detailed review documenting various stages of the burn-in process, please >>>CLICK HERE FOR REVIEWS and COMMENTS<<<
A truly unique product for the audiophile who demands extreme performance
The V-Cap OIMP series is NOT a “rebrand” or relabeling of an already existing product, but a unique new capacitor design that has been meticulously engineered and handcrafted in the U.S.A. V-Caps are manufactured to the specs of VH Audio, and are only available right here and approved modification industry professionals. Because there will be NO dealer network, we are able to offer audiophiles arguably the finest capacitors on the market today for a price up to 20-50% below typical dealer retail pricing.
The V-Cap OIMP series are available with a tolerance of +/- 5%. Two and a half and one percent tolerance may be available at additional cost. Each and every capacitor is inspected and tested at TWICE the maximum rated voltage PLUS 10% before it leaves the factory. This ensures long life, reliability, and the ultimate in performance.
* The 47 uF 150V OIMP V-Cap does NOT utilize a brass canister.
最后编辑sprs 最后编辑于 2007-11-12 16:38:24
回复: 纸膜油浸电容和现代薄膜电容的完美结合
[译文] 我自己翻译的,呵呵请指教。
V-cap OIMP 参考级别油浸电容
V-cap OIMP系列(油浸金属化聚丙烯)薄膜电容是一系列广泛的科研究和开发的成果。来自世界各地的电子、化学和材料学等行业最顶级的科学家,并与音响产品中最最著名的金耳朵们聚集在一起,研制出了一套特有的金属化和处理工艺,并创造出了世界上最通透最有音乐味的油浸电容。正是这个团队,曾经创造了世界上最好的电容V-cap TFTF特富龙电容。
改进的稳定性和品质
油浸电容长久以来被音响发烧友推崇用于电源供给、音响分频器和各种信号通路。“V-cap工程学小组”开发了V-Cap OIMP系列电容,通过一个特别设计的金属化聚丙烯薄膜,完美的结合了纸膜油浸电容平滑的音乐感,以及现代超级电容的高透明度和长期的稳定性。我们的化学薄膜是超稳定的,这意味着在电容长长的一生中可以保持一贯的高品质。
最适合的原料,完美主义的设计标准,和强迫症式的质量控制
选择最好的薄膜材料做好V-Cap油浸电容最重要的一步,选择极佳相位特性的薄膜缠绕技术已经使得声音好的让人晕倒。但是我们更进一步开发了特有的油浸工艺,达成了最高等级的音质、可靠性和长期稳定性。
不计成本的,V-Cap设计团队额外的选择了铜管,相比较测试过的所有其他材料,铜管的声音更加的透明和坚固。铜管的密封也是采用了订制的音响级别的材料和帽,有效的排除了任何可能物理损坏和电损坏。这意味着更加高效的,没有漏电,很低的DF/ESR,超越了传统油浸电容的极限,创造了新的最高标准。V-cap OIMP电容的所有设计、材料选择和处理工艺是如此的科学化和工程化,以至于我们大胆的对一手购买者提供一个空前的终身质保。下面是详细内容。
在2004年11月完成的Beta测试流程,一组选出来的发烧友和音响设备制造者被给予了这些电容,没有告诉他们任何关于电容的信息,包括类型和内部结构,仅仅告诉他们容量和电压值,以期达到最公正的测试结果。关于这次测试者的注释和非常细节的评测文档以及过程信息请参院这里>>>CLICK HERE FOR REVIEWS and COMMENTS<<<
献给极端音响发烧友的一款真正独一无二的产品
不同于其他,V-cap OIMP系列油浸电容决不是任何重新贴标签现有产品,而是新设计的一款独一无二的电容,精心的以科学化的流程在美国手工生产。通过VH Audio公司出售,同时提供给音响设备生产厂家。我们通过简单的销售方式,比传统的多级代理商分销体质节省20%~25%的零售价格。
V-cap OIMP系列油浸电容提供±5%的误差,可以订制±2.5%或1±%精度的电容,每一支电容离厂之前都采用超过额定电压10%的电压,完成两次严格的测试,保证了长期寿命,可靠性和后期的音质。
*附录47uF/150V的油浸电容没有使用铜管
最后编辑sprs 最后编辑于 2007-11-12 16:37:24
上周末这款油浸电容在上海有点小轰动。
上周末这款油浸电容在上海有点小轰动。
据当事人短信描述,当这未褒开的油浸电容一开声的时候,全部在场的人都中毒倒地不起。说是不但解析力高,关键是音乐感太好了。转听LP的一个烧友也开始一张一张的去播放所有收藏的CD唱片,说是一点数字味都没了,解析力和音乐感并存。
最后编辑sprs 最后编辑于 2007-11-12 16:40:48
回复:纸膜油浸电容和现代薄膜电容的完美结合
V-cap TFTF特富龙电容应该引起大轰动!
对V-cap TFTF特富龙电容一直心思思。。。
建议sprs组织一次“V-cap TFTF特富龙电容巡回试听活动”,可由对此电容心思的烧友自愿报名并交付押金同时承担一次快递费,活动结束后退回押金, 建议选用0.47uf和2.0uf两款TFTF特富龙电容作试听。
或者按地域为单元,由该地区一人总负责并交付押金,负责人组织该地区的试听活动。
sprs兄:
V-cap TFTF特富龙电容是用在电子管功放上吗?
原帖由 wxs 于 2007-11-12 16:53:00 发表
报名.
原帖由 wxs 于 2007-11-12 16:51:00 发表
建议sprs组织一次“V-cap TFTF特富龙电容巡回试听活动”,可由对此电容心思的烧友自愿报名并交付押金同时承担一次快递费,活动结......
V-cap已经很轰动了,我以为大家知道,云南某版主已经搞了好多了。成都的发烧友前前后后也已经拿下20多只。这个东西很有意思,说上一个城市就呼呼啦啦上好多只,而不上的城市零零星星的或者干脆一只都没有。
wxs 提的是个好注意,当然我希望是以每个城市为一个据点的,组织人是博士或者博士最好,最好每个地区有5人以上参加的。我和欧博的马经理商量下,我觉得提供两只0.1uF的比较容易,大家可以讨论下,如果觉得0.22或者0.33的更合适,也可以商量。当然第一站,是要负责褒电容的,500个小时,提示下,我自己褒过,很痛苦很痛苦。褒的时候是痛苦的流泪,但是褒出来后是幸福的流泪(附注:都是在心里流,男子汉不形于色)。
最后编辑sprs 最后编辑于 2007-11-12 17:50:33
原帖由 名琴LP 于 2007-11-12 16:56:00 发表
sprs兄:
最主要的用法是用在胆机电子管之间的信号耦合。或者功放输入的隔直流电容,或者CD以及前级输出的隔直流电容。如果你有胆机,前级还是后级都可以,自己打开看下,可以看到至少2颗大个的薄膜电容,替换同容量的电容既可。
还可以用在DAC的LPF电路,当然V-cap最小的只有0.01uF的,因此要专门为V-cap设计的LPF电路才可以。DAC芯片本身也需要一些小电容,这里也非常适合用特氟隆电容。
还可以用在电源供电部分,英文说是by pass,有翻译为旁路电容的,也有叫校正电容的,就是在原大电容上并小电容提高音质,一般在运放旁边都有两个0.1uF的小电容,成品机多用红Wima的,红Wima的太火爆,用这个之后声音会好很多,当然这种用法的确太奢侈了。
关于特氟隆电容和油浸电容。
首先两者容量范围是不同的,特氟隆电容是0.01~3.3uF,主要用于信号耦合和滤波。油浸电容从1uF~47uF,用于前级输出或者音箱分频器网络。
其次两者的追求不同,或者说设计目的不同。TFTF特氟隆电容的设计是要造就世界上最好的电容,它最大的特点是平衡,就是说解析力也很高,速度也很快,同时乐感也很好,都很好,达到一个近乎完美的平衡点。V-cap本身的解析力天下无敌,但是他的音色平衡度才是它最大的优点,这一点来源于它的老版Chris先生长的25年的音乐演奏生涯。
而虽然V-cap TFTF特氟隆电容拥有了至高的平衡度,可以让本身很靓的录音表现的无比美妙,但是对于本身不好的录音表现的就是录音的缺点。而油浸电容特有的音乐味也是非常美妙,无时不折磨着每个发烧友,而市面上的油浸电容大多因为工艺问题,寿命有限。因此Chris决定再开发一款油浸电容来获得油浸电容特有的美妙音乐味,同时还要保证发烧友可以听过世的长寿稳定性。而且确实如此,Chris老版给OIMP的质保是一手终身,就是说第一手买家在去世之前都保修。所谓一手,是为了防止爷爷听了留给孙子,轮到孙子的孙子听的时候坏了就不能保修了。当然Chris并没有记录下购买人的身份和年龄....
最后编辑sprs 最后编辑于 2007-11-12 17:53:22
