给大家推荐一个米国的器材网站 [复制链接]
查看: 2746|回复: 8
诚求叶立老师的前级,有源、无源的都要!
回复:给大家推荐一个米国的器材网站
好象没人气,东西也少.
www.jasmineaudio.net
回复:给大家推荐一个米国的器材网站
PP不错
回复:给大家推荐一个米国的器材网站
价格太贵,vcap的老板开的www.vhaudio.com比它便宜多了。
古河的F1-11插尾,usahifi卖49,vhaudio卖39。
回复: 给大家推荐一个米国的器材网站
这个看起来好怪异
Anthony Gallo : Reference 3 - NEW
Frequency Response: 34Hz - 50kHz +/- 3dB
Frequency Response(active bass): 22Hz - 50kHz +/- 3dB
Impedance top terminal: 8 Ohms
Impedance lower terminal: 4 Ohms
Sensitivity: 88 dB/1 Watt/1 metre
Power Handling: 350 Watts
Driver: Dual 4" carbon fibre midrange drivers Custom 10" dual voice coil bass driver
CDT Tweeter: 300 degree dispersion 3kHz - 50kHz
Midrange Driver Material: Carbon fiber
Dimensions: 36.25" (H) x 8" (W) x 14" (D) with grill 35.5" (H) x 8" (W) x 14" (D) w.out grill. Add 2 to 2.25" for spikes and spike protectors.
Weight: 47lbs each
Connections: Gold plated all metal binding posts for secure wire connection
Finishes: Black with black or stainless accents, black, Cherry or Maple base.
A three-position transformer-coupled tweeter level control accommodates a range of room acoustic variables allowing -/+2dB cut and boost by selecting different transformer taps.
A pair of 4-inch hyperbolic carbon fiber drivers - each housed in its own ultra rigid, low diffraction 5-inch stainless steel sphere - handle the critical midrange frequencies without a crossover to the CDT II™ tweeter.
Low frequencies are reproduced by a long-throw, dual voice-coil 10-inch woofer. That driver is acoustically loaded into a sealed alignment that includes the Reference 3's hollow cast aluminium chassis which is filled with S2 technology air density treatment.
The Reference 3 is equally comfortable being used in stereo or home theater set-ups.
回复:给大家推荐一个米国的器材网站
http://shopping.kelkoo.co.uk
这个查查价格也不错
不平衡啊,国外那么便宜,国内那么贵!
诚求叶立老师的前级,有源、无源的都要!
回复:给大家推荐一个米国的器材网站
没关系呀,可以直接直接在国外买,多掏20多刀的路费就行了。
我已经在国外买了好多东西了。Wattgate的320i和5266i插头插尾,一套才33美金,划人民币250块钱。一次多买点,选最慢的快递(10天到1个月不等)路费控制在5%左右。
直接信用卡就可以刷,很方便。
回复: 给大家推荐一个米国的器材网站
报关麻烦吗?
回复:给大家推荐一个米国的器材网站
元件类,线材之类的不用报关。
成品箱和机器是需要一定费用了。
