Linn Studio Master 格式尝试 [复制链接]
查看: 1927|回复: 0
从linn records网站购买了一首Studio Master格式的无损压缩音频。
linn网站上的介绍
Studio Master FLAC
If absolute sound quality is what you want then this file is best for you.
FLAC files are lossless at various high bit rates, for example, 48KHz, 88.2KHz and 96KHz (check each title for actual details).  The quality is identical to that of an SACD (Stereo only). The format will be dependent on the actual recording method we used originally. No DSD files are offered as it is not possible to play them back on a PC so an equivalent PCM format is offered. These files offer true "studio quality" and are what was used by Linn to produce the production version of our CD releases. Be sure to check compatibility with your computer sound card etc before you download a file and note that large amounts of storage space are required for each track.
FLAC files can be imported into many media players, such as the Klimax DS digital music player, but unfortunately Microsoft does not yet support high bit-rate FLAC, so these files will not play in Windows Media Player. There are many other FLAC players available such as Media Monkey and Foobar.
FLAC Studio Masters play in Play and VLC, but not in Cog or MPlayer. It is however very easy to transcode FLAC to several other lossless formats.
文件正在下载中。计划用专业录音卡输出24bit/88.2khz数码信号到msb platinum解码器。明天试听。
