返回列表 12345678» / 10
2015威虹特价清仓开始了 [复制链接]
查看: 55051|回复: 94
先用一对捷克诗韵书架箱Bonbonus 试水:
全新特价2980元
诗韵书架箱,捷克原产由意大利音响工程师投资设计,捷克原产。该箱根据我们的经验使用的单元应该使用的是丹麦威发的,高音采用了绅士宝的制造技术,纸盆低音单元,声音绵密柔和,一起合成,人声弦乐悦耳动听,是小型聆听空间的至佳选择。
产品参数:
Mid-bass frequency unit       132 mm exclusive custom made Xavian
High frequency unit             26 mm exclusive custom made Xavian
System type                       2-ways damped bass-reflex, front aluminium bass-reflex ports
Cabinet                              hand-made, real wood veneers
Frequency response            (-3 dB on reference axis): 59 - 20000 Hz
Connection                        1 pair of gold plated binding posts
Nominal impedance            8 ohms
Crossover frequency           3000 Hz
Sensitivity (2,83V/1m)        87 dB
Dimensions (HxWxD)          273 x 160 x 200 mm
Net weight (1 unit)             4,7 kg
图片中的音箱为枫木色,全新开箱拍片,尚未通电开声,另有原包:枫木色一对,鸡翅木色一对。
最后编辑新航线 最后编辑于 2015-12-15 11:27:11
捷克诗韵高端系列 MIA 书架箱一对成列品特价:6280
该箱为胡桃木贴皮,采用的是威发顶级单元,高低音均为铸铝骨架,声音稳定扎实,既赋予韵味又饱满甜润。
难能可贵的是在小型空间中,也有良好的动态和规模感。
Mid-bass frequency unit       149 mm Vifa-Peerless Premium Line, paper membrane.
High frequency unit             25 mm Vifa/Scan-Speak, treated fabric soft dome, wide surround.
System type                        2way damped bass-reflex with massive Aluminium rear port
Cabinet                              22 mm MDF handly crafted, available stand Classico mounting.
Frequency response             ( -3 dB on reference axis ): 55 - 40000 Hz
Connection                         1 pair of singly mounted XAVIAN binding posts.
Nominal impedance             4 ohm
Crossover frequency            3000 Hz.
Sensitivity ( 2,83V / 1m )     86 dB
Dimensions (HxWxD)          180 x 300 x 220 mm
Net weight (1 unit)             7,1 kg
最后编辑新航线 最后编辑于 2015-09-06 10:19:24
JBL 4338 全新成列品特价 41800元
该箱于9月1日开箱试声,现正作为静态成列,声音柔和宽松,能量强大,音乐的适应面宽广,从交响乐到人声爵士均有一流的表现。
Format                                                   3-way floor type 380mm diameter
Use un                                                   LF   380mm diameter pure pulp cone woofer <1500FE>
                                                            HF   75mm diameter aluminum diaphragm compression driver <435Al>
                                                           UHF  25mm diameter pure titanium diaphragm compression driver <045Ti>
Impedance                                              8Ω
Permissible input                                    300W (RMS)
Output sound pressure level                     93dB (2.83V/1m)
Frequency characteristic                          35Hz ~ 40kHz (-6dB)
Crossover frequency                               750Hz, 9kHz
Dimensions (W × H × D)                         549 × 921 × 375mm
Weight                                                  63.4kg
最后编辑新航线 最后编辑于 2015-12-23 16:46:08
已售
B&W PM-1书架箱运用了B&W鹦鹉螺的技术,实际上805的缩小版,较为适合在细小的房间中运用,音色甜美中富有高贵的气息,既清澈透明,又有润泽度与厚度,弦乐与人声既感性娇艳又不失端庄,是细小房间中的最佳选择,   此音箱静态出样,极少开声还没有进入“开煲”状态。
最后编辑新航线 最后编辑于 2015-11-22 12:58:39
已售
美国SilrverLine书架箱   该箱均采用丹拿特制单元,高音和低音都是双音圈设计,不但分析力更为出色,而且能量充沛,音色温暖。灵敏度也有显著的提高,一般中等功率的功放都可以推出出色的音乐效果,当然哈哈功放的基本素质不能太低哦。
最后编辑新航线 最后编辑于 2015-11-22 12:59:18
顶,威虹做生意挺实在,这样明码标价的帖子更是好
冷门品牌或产品当然明码标价。
热门的东西经销商多,顾虑也是可以理解的
顶啊!
好箱子好价格
音乐中,最重要的并不在音符里!——古斯塔夫•马勒
