这家伙香港提货多少钱? [复制链接]
查看: 5095|回复: 13
The  Andra 2
Frequency Response : 25Hz to 25kHz
Impedance : 6 ohms avg.
Sensitivity : 88.5dB @ one watt/one meter (91dB in-room)
Power Recommendation : 30 watts (small room) to 300 watts
Inputs : Two sets of rhodium binding posts enable bi-wiring or bi-amping. Crossover frequency at binding posts is 135 Hz.
Woofer System : Two - 12" woofers with large, 4" voice coils in a push/push compound loading. 15Hz to 135 Hz range.
Midbass/Midrange System win 6" midrange drivers with 3" voice coils. 135Hz to 1.8kHz range.
Treble System : 1" fabric dome tweeter. Hi-Dynamic Range voice coil/magnet system. 1.8kHz to 35kHz range.
Enclosure Design : Wall thickness of 1.53" to 1.79". Compound woofer design using 100% cavity stuffing, sealed transmission line midrange loading with 100% cavity stuffing. Crimped, non-settling Dacron and felt is used throughout.
Crossover Design
: 6dB/octave symmetrical filters at 135Hz with Zobel impedance compensation; 24dB/octave symmetrical filters at 1.8kHz. Custom circuits are time, phase and frequency aligned to provide flat amplitude response as primary target, with +/- 15 degree listening window.
Designed response window is centered on tweeter axis.
Dimensions
: Footprint is 15" x 18". Height is 44".
Net weight per loudspeaker is 210lbs.
回复:这家伙香港提货多少钱?
只能告诉你一个二手价,我刚卖了,陶街给我八万七.
回复: 这家伙香港提货多少钱?
原帖由 cktony 于 2008-6-12 17:30:00 发表
送我好过啦
回复: 这家伙香港提货多少钱?
全新的呢?
回复: 这家伙香港提货多少钱?
不知潘志强兄知道吗?也可PM我啊。
回复: 这家伙香港提货多少钱?
原帖由 聆至静 于 2008-6-12 18:11:00 发表
送我好过啦
考虑你家己有毒物,送你如何安置,怕你一山不能藏二虎,服侍完东宫,西宫又说;我要.
那我变成好心造坏事了
最后编辑cktony 最后编辑于 2008-06-13 09:30:56
回复:这家伙香港提货多少钱?
回复:这家伙香港提货多少钱?
好家伙.
回复:这家伙香港提货多少钱?
metalfan兄,你好,我也很想购买ANDRA2,不好推,主要是肚子里那个被动12寸低音,收到我短信没
回复: 这家伙香港提货多少钱?
送我好过啦
聆兄
想深一层,还是送你好,想她时到你家走一转便OK了.
