晒晒我的 Avantone Active Mixcubes [复制链接]
查看: 1927|回复: 0
迷你-监听器新的纪元有新的力量
应用于
有效记录的录音/mixdown 检测
设计目标
Avantone Active Mixcubes 被设计具有高辨识率, 使迷你监听器的能力为全范围为固定的或细微的区域。
辅助的工程方面将创造成一种永久的一个完整范围的转换器。
性能目标
主要的设计工作场所为使用在表现比较高的声音水平及一个宽的音频范围两方法的大监听器。
然而……在高音质声音的新进的发展中,仍然会听到你所混合的会听起来有时的需要有 " 向低音 - 挑战 " ,像是电视, 时钟收音机、计算机, 汽车音响,ipod , 等等。
背板控制说明/连接方式
balanced in: this “combo XLR” input accepts a BALANCED male XLR plug as well as a 3-conductor BALANCED TRS1/4” or a2 conductor UNBALANCED TS1/4” male plug. For unbalance operation with a TS connector the minus signal is automatically grounded.
XLR
TRS
RCA
HOT(+)
Pin2
Tip
Tip
COLD(-)
Pin3
Ring
SHIELD(GROUND)
Pin1
Shield
Shield
@-10 db LINE LEVEL: this input accepts a male RCA/Phono Plug at a -10 unbalanced operating level.
@SYSTEM GAIN: this variable trim set control adjusts the sensitivity of the signal that appears at the input. rotating the control clockwise increases the sensitivity while a counter-clockwise rotation decreases sensitivity. The adjustable gain range is from -30 to -6 d B. A setting of +6 allows a full, unimpeded signal to be sent to the amplifier. The trim pot may be adjusted with a small flathead screwdriver. Please note…when the signal appearing at the input is too hot, the amplifier can overload causing distortion and possible damage to the speaker. If overload occurs, attenuate (decrease) the input level by turning the trim pot counter-clockwise a few clicks.
@ON/OFF Toggle Switch: this switch turns the amplifier section on and off. The unit is still receiving power from the transformer however. In the “OFF” position a RED LED will be illuminated on the lower right front of the MixCube cabinet. When in the “ON” position the LED will be BLUE.
@AC IN: this input is only to be hooked up to the proprietary AVANTONE Power Supply Transformer. Tighten the cable/connector securely for reliable operation. Note: There is a switch on the transformer for selecting the proper AC/MAINS operating voltage for your location.
放置方式
当放置在台子或控制台上的 AVANTONE MixCubes 以桥连接时用户应把他们留在与使用时耳朵水平的高度,而且最好轻微地按某一角度转动在向使用人员。最适宜的音响放置距离为把监听器放在自彼此的距离等于和与使用者耳朵间的距离,即两音箱与使用者三者分别为一等边三角形三个端点。
MixCubes 在使用过程中把他们放置靠近显像管,电视的监视器或电视的其它部位是不会引起任何的问题。 他底部的 5/8"*27 mic的垫脚也将会使他在不寻常的工作场所中允许你有更多的定位方式来放置他们以便更好得为您的目的发挥其功能
Mix Cubes的连接方式
在使相关电源和你的Mix Cubes上连接之前请花一些时间确定适当的 AC 电源插头的提供电压与Mix Cubes设定电压相互适合。 开启时所有的监听器均应为最小音量控制开启。 所有的其他播放设备或你的控制台设备也应该在打开 MixCubes 之前如上使用小音量,如此可避免瞬间的大声引起强烈振动和影响。 输入 " SYSTEMGAIN" 控制处为了避免开始的上时意外的超载,在出厂时的设定均为最小量被设定。这一预默认预设使用户在充分的使用时时监听器更安全的输出关于来自播放设备及控制台的送给输出。
规格参数
系统类型:
有源(自我)有保护全部-范围双音响
频率回应: 90赫兹 -17000 赫兹 (接近音乐会效果)
最大 SPL: 101个分贝 1 menter(粉红的噪音)
功率: 35个瓦特 RMS 分类 A/B
噪音: 95Bb" 一 " 重量
冷却: 对流方式 / 铝质鳍形散热片
扬声器: 8个欧姆 5.25" 阵容铝框架 / 圆锥体纸盆
箱体: 密封的设计 /18 毫米 MDF/ 与达克龙听觉的填塞物
输入: XLR& TRS+4/均衡的 &RCA/-10 不平衡的
箱体规格:
165 毫米 *165 毫米 *106 毫米 (箱体深度)
165 毫米 *165 毫米 *241 毫米 (整体深度)
箱体重量:
4 公斤/8.8 磅 (每个)
个人英文能力较差,翻译可能有误望见谅!!
