关于175瓦和190瓦Simaudio W5后级的区别 [复制链接]
查看: 5125|回复: 14
最近有几位朋友都达电话问我,Simaudio W5后级有两个版本,175瓦的和190瓦的,到底如何鉴别是175瓦还是190瓦的后级呢?因为他们听二手JS说,如果电源开关和Standby开关都在后面的,就是175瓦的,电源开关在后面而standby开关在前面的是190瓦的。
为此,偶做了一点调查,也向Simaudio厂方发邮件进行询问。昨天得到了厂方的官方答复。
然后呢?
我曾经用过一台Simaudio W5,我就将这台W5的序列号发给了Simaudio厂方。
图片是厂方给出的官方答复,其中包括了判断175瓦和190瓦的区别。
jpg(2008/12/16 9:04:16 上传)
最后编辑SMERT 最后编辑于 2008-12-16 09:04:15
图片比较小,我就把回复的内容贴出来:
其中一句话就提到:175瓦的版本是采用TO3金封功率管,而190瓦的版本用的非金封的功率管。
Dear Mr. Thomas,
The difference between 175 and 190 watts is not noticeable (just 0.3dB difference).
Your unit is a 190W per channel, built with new power transistors in a different casing. (the W-5-175W per channel used 10 x TO3 power transistor casing.
Now, you need to know that the power will follow the speaker load: If your speakers are rated with 8 ohm, you will have 190W per channel. If your speakers are 4 ohm, you will have 280W per channel available. Keep in mind that we (at Simaudio) are conservative with power amplifiers. Our production is always rated with the lowest level of distortion.
Thank you for your confidence in our product.
Sincerely,
Adrien Rouah
Worldwide Service & Sales Support
95, Chemin du Tremblay Unit # 3
Boucherville, QC, J4B 7K4
Canada
Tel: 450-449-2212 ext:215
Fax:450-449-9947
e-mail: adrien@simaudio.com
www.simaudio.com
最后编辑SMERT 最后编辑于 2008-12-16 09:16:29
美国Stereophile对于Simaudio W5的175瓦和190瓦版本的区别也有描述:
http://www.stereophile.com/solidpreamps/167/index10.html
"The internal changes are straightforward: Filter capacitance in the power supply has been increased by 40,000µF. (Each of the eight caps was increased by 5000µF, for a total of 216,000µF vs the previous 176,000µF.) "
内部的区别非常明显,电源部分的滤波容量增加4万微法(8个电容每个的容量增加了5000微法,总容量从17万6千微法增加到21万6千微法)
"Finally, the output stage now uses 10 (vs 8) Motorola bipolar output transistors per channel. "
输出晶体管的数量增加到每声道10个(之前是8个)摩托罗拉双极性功率管。
最后编辑SMERT 最后编辑于 2008-12-16 09:27:19
还是没有道出如何鉴别175和190呀?你W5的STANDBY在前面还是在后面?
BRINKMANN-FM223-FM115-KAISE
可以从内部图片看出使用金封TO3功率管的版本和使用非金封功率管之间的区别
jpg(2008/12/16 9:18:32 上传)
从官方的答复和Stereophile的测评,175瓦和190瓦的版本之间的区别,主要就是使用何种封装的功率管和滤波电容的容量
175瓦的Simaudio W5:使用摩托罗拉TO3金封功率管,每个声道4对,滤波电容的容量为17万6000微法
190瓦的Simaudio W5:使用非金封的双极性功率管,每个声道5对,滤波电容的容量增加到21万6000微法
所以根本不是什么开关在前在后的问题!我好像从来没见过哪台W5后级Standby开关是在前面的!不知道其他W5用家是否见到过。
最后编辑SMERT 最后编辑于 2008-12-16 09:24:02
原帖由 WILLIAMHOO 于 2008-12-16 9:18:00 发表
鉴别方法已经写了,主要就是滤波电容的容量和功率管的不同。
我那台W5的STANDBY在后面的,我两个朋友从代理买的行货190瓦的W5,其STANDBY也是在后面的。
顺便问一下, SIMAUDIO I5 和 I5 LE 限量版有啥区别? 有没有对比过的朋友啊, LE版本比普通版本好多少?
美国JPS, 美国Sound Anchors, 美国ABYSS, 美国Cavalli
http://shop34547859.taobao.com/
