Black Diamond Racing在国内有代理商吗? [复制链接]
查看: 6466|回复: 24
静电 丝带 平板 号角 一个都不能少!
台湾算是国内吗?台湾有,是上瑞公司。
用过,品尝过的才敢叫好!
回复 2# kkhuang 的帖子
TW当然是中国领土的一部分,不过台湾确实遥远了点.
静电 丝带 平板 号角 一个都不能少!
可以请台湾的朋友代购,或国外买啊,这里有不少台湾朋友,也有不少能在国外购物的朋友。
用过,品尝过的才敢叫好!
主要是现在对BDR的型号还有点晕
最近北京天热,家里用的SPECTRAL SDR-1000的胶脚由于长时间开机软到跟家具沾在一起,(SB的SPECTRAL!我CAO他二大爷!) 记得以前咨询原厂建议也是说最好能更换原厂的胶脚为BLACK DIAMOND RACING的,解决老化问题.
BDR最糟糕的是没有官方网页,想找资料很麻烦.如果是一般的找钉也好办,不过我是要找合适的脚加钉替换原厂的,对于螺纹尺寸之类的可能就要先搞清楚再一次搞定了.毕竟一套四个价格也不是太便宜,万一买错了就麻烦了.
静电 丝带 平板 号角 一个都不能少!
根据现在的情况估计应该用 四套MK-IV Cones + Mini Pits  但是怎么跟机器原来的螺栓接合还是需要有经验的人帮看下
静电 丝带 平板 号角 一个都不能少!
Black Diamond Racing Pyramid Cones Mk3
140x4=人民币560元一套三件, 值得买吗? 到底有没有效果的?
Black Diamond Racing Pyramid Cones Mk3.
Set of 3 cones new in box.
The BDR Pyramid Cones are the basic building blocks of the BDR system. They are, in most cases, the initial interface in a vibration control system, and should be the first pieces utilized in developing your setup.
The Pyramid Cones have proven an effective means of vibration control under all types of components: speakers, turntables, transports, CD players, preamps, DAC's, amps, crossovers, video equipment, even medical and computer equipment.
With a crush point of 10, 000 pounds each, the Pyramid Cones can be used virutally anywhere. The best resultswill be obtained when the Cones are placed under or near the critical elements of the component: drive mechanism, power supplies, transformers, tonearm mounts, motors, etc.
The proper placement will significantly effect the performance of the Cones.
The rule of thumb is the tip of the Cone should be toward the resonant surface. For example, under a CD transport sitting on an MDF shelf, the tips of the Cones should be pointing down.
A general guideline is to strat with the Mk3 Pyramid Cones under solid state and digital equipment, and the Mk4 Cones under tubes. (Please note: this is only a suggested starting point, as we have a number of cases where people prefer the opposite Cones under the exact same component. Room acoustics, rack structure, personal taste and other considerations all come in to play.)
In addition, the two different types of Cones may be mixed together for "in-between" results if desired. For reaching the next level of performance.
最后编辑hopeman 最后编辑于 2009-06-28 11:50:05
上瑞今年会参加北京音响展,到时候可以去看看
BRD和HRS应该是目前国外比较火的,但是价格都不便宜
器材只是个过程  音乐才是目的地
长篇连载 ----- 不悔的执著,黑胶之路-------
http://www.tubebbs.com/thread-95582-1-1.html
看来也只有等音响展了,要不买回一些根本安不上的东西就麻烦了.现在SPECTRAL瘸了条腿,只能先用别的脚钉撑起来了.
想买BRD的主要原因还是原厂推荐使用,应该跟SPECTRAL的性格比较合吧.
静电 丝带 平板 号角 一个都不能少!
可以到www.myav.com.tw有不少人卖二手,不过价钱很贵,四个要10000新台币,2500人民币啊
用过,品尝过的才敢叫好!
