有没有Cary Xciter解码器用家,谈谈效果如何 [复制链接]
查看: 1792|回复: 1
有没有Cary Xciter解码器用家,谈谈效果如何。
在网上看报价在8K左右,支持192k,内部带升频功能,接收到的信号直接转换到32bit/192K(网上是这么写的),看着不错,不知实际听感如何。和DAC-1有没有比较过的?
The USB output from the PC has noise. When the signal is input over USB into the DAC, it bypasses the receiver chip and is sent directly to the CM-108 device. The digital stream is stripped as the device separates the clock and data signals. It then re-clocks the digital stream which basically means it has reduced any jitter and/or noise to extremely low levels.The re-clocked stream is then directed to the main AKM processor chip where it is upconverted to 32 bit / 192kHz and then outputted to the analog jacks on the rear panel of the DAC.
