WEISS 火线驱动重大更新 音质稳定性大幅提升 Weiss用家注意升级... [复制链接]
查看: 2754|回复: 2
重大更新版本为4.0.0
请大家到www.weiss.ch下载
改进和提升请看:
Version 4.0.0
Issues resolved:
CASE
DESCRIPTION
OS
22
MIDI latency has been improved.
XP/Vista/Win7
277, 1009
MIDI data throughput has been improved.
XP/Vista/Win7
368, 827, 962, 1000
The driver's streaming engine has been rewritten to improve performance, stability, and reduce latency. It is optimized to work on both Microsoft's new and legacy 1394 OHCI bus drivers. ASIO performance when using small buffer sizes is vastly improved.
XP/Vista/Win7
412
The driver's ASIO interface has been refactored to improve performance and compatibility with ASIO host applications.
XP/Vista/Win7
455
The driver's handling of DPC delays has been greatly improved. The driver will also no longer send a kASIOResetRequest event to ASIO host applications when a streaming discontinuity occurs due to a DPC delay.
XP/Vista/Win7
705, 739, 806
Added support for Dynamic Format Change on Windows 7. The sample rate used by WDM audio will now follow the sample rate set in the Control Panel.
XP/Vista/Win7
714
MIDI output is now more accurately aligned with the audio.
XP/Vista/Win7
744
The driver's ASIO interface now supports buffer sizes starting at 32, 64, or 128 (depending on the current sample rate) and increasing by a power-of-two.
XP/Vista/Win7
777
On Windows 7, the WDM audio input's gain was too sensitive and could cause clipping.
Win7
794
The driver's new streaming engine avoids almost all of the performance issues that are present in Microsoft's new 1394 OHCI bus driver in Windows 7.
Win7
805
A rare BSOD could occur when a system would wake from sleep.
XP/Vista/Win7
815
The driver could stop responding after switching to 176.2kHz or 192kHz.
XP
833
The driver would incorrectly take a second longer to initially start streaming when a device was first connected.
XP/Vista/Win7
838, 867, 910, 919, 921, 935
The WDM audio driver has been rewritten to use a new Windows streaming model in order to improve performance and to take advantage of newer features.
XP/Vista/Win7
857
A rare BSOD could occur when a device was attached.
XP/Vista/Win7
920
A WDM output's audio could become silent when the Front L or Front R channel was remapped to another channel.
XP/Vista/Win7
931, 938
A WDM input or output audio channel could become distorted after a change to the channel's mapping.
XP/Vista/Win7
934
Fixed a minor memory leak in the MIDI driver.
XP/Vista/Win7
940
The WDM audio input can now be configured as either a mono or stereo source.
XP/Vista/Win7
990
The performance of the WDM audio driver has been optimized.
XP/Vista/Win7
999
The ASIO driver could be delayed up to 8 seconds in starting up.
XP/Vista/Win7
1007
Support for AC3 audio was not fully implemented.
XP/Vista/Win7
1008
The Operation Mode settings have been renamed. On both platforms there are four modes available: Low Latency, Normal, and Safe Mode Levels 1 to 2.
Old Setting[size=+0]New Setting
NormalLow Latency
Safe Mode Level 1Normal[size=+0]
Safe Mode Level 2Safe Mode Level 1
Safe Mode Level 3Safe Mode Level 2
On Windows, the Operation Mode setting no longer affects the minimum ASIO buffer size.
XP/Vista/Win7
1013
The Control Panel could crash if an exception occurred during the initial connection to the driver.
XP/Vista/Win7
1017
The Control Panel could take up to 50 seconds to launch if an exception occurred during the initial connection to the driver.
XP/Vista/Win7
1019
The driver's streaming engine would not recover correctly after a large DPC delay (>24ms) resulting in distorted audio.
XP/Vista/Win7
1020
A BSOD could occur when playing or recording WDM audio.
XP/Vista/Win7
1025
The driver was not correctly enabling a workaround that decreases CPU usage on Windows 7.
Win7
1029
The Control Panel's Event Log window is now wider by default, and is now resizable.
XP/Vista/Win7
1033
The ASIO driver now reports the correct ratio of input latency and output latency.
XP/Vista/Win7
1034
When using stacked devices, the driver could send invalid packets for a short duration that would cause the slave devices to take longer to lock.
XP/Vista/Win7
1035
Fixed a minor memory leak in the AC3 encoded audio driver.
XP/Vista/Win7
1038
The Control Panel's DPC graph could be only partially drawn.
XP/Vista/Win7
1039
The Control Panel's DPC tab now indicates that it is not available when there is no device attached.
XP/Vista/Win7
1041
AC3 encoded audio was not being streamed correctly.
XP/Vista/Win7
1042
The Control Panel's DPC tab was not using the correct DPC delay thresholds when recommending an Operation Mode.
XP/Vista/Win7
1043
Improved performance when using stacked devices on Windows 7.
Win7
1049
The Control Panel could crash when moving the mouse wheel over another application's window.
XP/Vista/Win7
1050
The performance of the driver when using stacked devices has been improved.
XP/Vista/Win7
1053, 1059
AC3 parameters are now locked when an ASIO or WDM application is using the driver.
XP/Vista/Win7
1054
A BSOD could occur when detaching a device while an ASIO host application was using it.
XP
1060, 1062
An ASIO host application's audio could become distorted if it was using a large percentage of CPU time to process its audio.
XP/Vista/Win7
1066
WDM audio could stutter when paused in some WDM audio applications.
XP/Vista/Win7
1072
An ASIO host application's audio could become silent after changing the sample rate.
XP/Vista/Win7
WEISS;AMARRA ;OYAIDE NEO Viard Audio
诚征全国各地经销/代理
TEL:18610296369
WEISS中国官方网站:www.sinoweiss.com
给力消息!不过怎么都是Windows的,那Mac呢?
无畏过往,不惧将来 ……
微信:Vincent666333
mac向来稳定,不需要频频升级(打补丁)
