Romanze 2013 - 装,继续装~~~ [复制链接]
查看: 12860|回复: 45
昨天下午接到师兄电话,藕订了大半年的冬冬到了。
最后编辑3L-AUDIO 最后编辑于 2013-04-16 01:22:53
藕乃草根
X3-06 EXOTIC T35
The Exotic T35 is a classic dome midrange tweeter with high sensitivity and a smooth, extended frequency response.
A coated fabric dome with integral surround manufactured by Dr. K. Müller in Germany  ensures excellent performance and consistency. This supplier was among the first in the world to offer fabric dome diaphragms, and did produce the diaphragm for the famous 1.5” Dome Tweeter H087, developed by Seas in 1968.
A high efficiency Alnico V ring magnet in a carefully designed system contributes to high sensitivity and low distortion. A large and well damped cavity in the pole ensures a low resonance frequency and smooth response.
A generously underhung 35mm voice coil wound from copper-clad aluminum wire further enhances the sensitivity. Flexible lead-out wires and venting holes in the aluminum coil former help reduce noise to a minimum.
A large diameter 7mm thick precision machined aluminum front plate with moderate horn loading ensures linear frequency response and represents an extremely stable platform for the magnet system and the moving parts.
Frequency response
The frequency responses above show measured free field sound pressure in 0, 30, and 60 degrees, mounted in a 0.6m by 0.8m baffle. Input 2.83 Vrms, microphone distance 0.5m, normalized to SPL 1m. The impedance is measured without baffle using a 2V sine signal.
Specifications
*IEC 268-5, via High Pass Butterworth Filter 2500Hz 12 dB/oct.
SEAS这段日子不知出了什么问题......
藕乃草根
E0049-08S W16NX001
Precision cast, machined and surface treated magnesium cone acts as a piston through the audible frequency band without showing any sign of midrange resonances.
A unique radial reinforced rubber surround reduces radial resonances and prevents surround break up at large excursions.
Heavy copper rings mounted above and below the T-shaped pole piece reduce non linear and modulation distortion and increase overload margin.
A copper phase plug reduces compression due to temperature variations in the voice coil, increases long term power handling capacity and eliminates resonances in the cavity inside the voice coil former.
The extremely stiff and stable injection moulded metal basket keeps the critical components in perfect alignment.
Large windows in the basket both above and below the spider reduce sound reflection, air flow noise and cavity resonance to a minimum.
Frequency response
The frequency responses above show measured free field sound pressure in 0, 30, and 60 degrees angle using a 10L closed box. Input 2.83 Vrms, microphone distance 0.5m, normalized to SPL 1m.The dotted line is a calculated response in infinite baffle based on the parameters given for this specific driver. The impedance is measured in free air without baffle using a 2V sine signal.
Specifications
*IEC 268-5 SEAS reserves the right to change technical data.
藕乃草根
藕乃草根
藕乃草根
藕乃草根
3l兄,你以前提供的3分频的那个网站因我的电脑重装系统没了,可否再贴一次,万分感谢。
什么3分频?
藕乃草根
嗯……用seas的單元做的(一個鬼佬网站)。
藕乃草根
