新西兰IMAGE Paragon2落地音箱 [复制链接]
查看: 12938|回复: 4
System type:3-way four speakers. Bass reflex and rear ported. Phase and time aligned
HF driver:Morel Supreme 110, 28mm soft dome, frequency matched pairs
Midrange driver:Morel 16cm Carbon fibre/Rohacell composite sandwich cone in a Uniflow Aluminium diecast chassis, 75mm underhung EVC, with Linear impedance copper sleeve technology. Separate midrange/HF (sub) enclosure
Bass drivers:2 x Peerless 21cm Nomex cone in rigid aerodynamic cast Aluminium chassis and ventilated spider. Separate bass (sub) enclosure
Room response:32Hz-22kHz
Averaged Sensitivity:90dB/1 watt
Impedance:4 ohms nominal
Dimensions(cm):113.5 x 26.2 x 48.3 (h x w x d) plus floor spikes
Weight:54kg each
Features:Accu-Bases, and Hand-turned adjustable solid brass floor spikes.
Bi-wire German WBT Gold-plated multi-way input terminals
jpg(2014/2/20 13:59:09 上传)
www.fymhifi.com
外观图
www.fymhifi.com
新牌子?
看外形想到wilson+某国产名牌
音乐的爱好者,好器材是为了好音乐服务的。
回复 3# 原木1号 的帖子
www.fymhifi.com
Image Paragon 2 Floorstanding Loudspeakers Overview Back in the good old days of 2007, I tagged along with Gary Pearce when he reviewed Image Loudspeakers’ top of the range Paragon floorstanders for a local tech mag. He described them as “world-class speakers” and I totally agreed with him. From the finish to the sound, the big Paragons did the job in a way that made me think that they were somewhat under priced, especially in an overseas context.
So when Chris Ball (Mr. Image Loudspeakers) got in touch to let me know that he had a revised version of the Paragons to show off, I knew that this would be a worthwhile and interesting session. Like the first Paragons, the new models were set up at Mark Erceg’s Gulf Harbour listening room, in the distant reaches of Auckland’s North Shore. Mark runs Audionut, and he imports some highly desirable hi-fi brands including Reference 3A, MBL, E.A.R and Kuzma among others. Audionut is currently the only hi-fi vendor able to sell Image’s flagship speaker because Mark knows them inside and out and can demo them to their full potential. That potential, as it turns out, is high.
The story behind the second generation of the Paragon starts with a new Morel speaker driver. Chris used Morel’s latest carbon fibre bass/midrange driver in the recent Petite Performa speaker. It was so good that he decided to implement this new driver range in the Revelation and Paragon models.
The $13,000 Paragons are large floorstanders measuring 113 x 26 x 48 cm (H x W x D) that at a glance look much like the first model. There’s the same dual cabinet design with two 8” Peerless woofers housed in a rectangular ported cabinet. Isolated from the bass cabinet is a shaped and angled sealed upper cabinet containing the new Morel midrange and a Morel Supreme 110 tweeter. This isolated cabinet design allows the drivers to be time-aligned and it keeps the bass drivers from interfering in any way with the critical upper frequency transducers. The side panels are now slabs of thick glass instead of custom wood; this glass is scratch resistant, anti-resonant and adds a hefty 12.5 kilograms per side, taking the speakers to a total weight of well over 50 kilograms each.
The Paragons are solidly built to say the least, with 38mm front baffles and 30mm thick walls constructed using laminates and dissimilar materials. The interior of the cabinets is also heavily braced, which when combined with the glass panels and the overall design, takes resonances down to the lowest levels Chris has yet achieved.
The finish is superb from top to bottom and front to back, even when examined with a critical eye actively looking for glitches. The leather covered front baffles and the subtle green shading from the front of each glass panel add a touch of class and luxury that elevates the design. The leather also improves the diffraction characteristics. The speakers boast Image’s Accu-Bases and hand-turned adjustable solid brass floor spikes, while the cable terminals are gold plated WBT units in a bi-wire configuration housed on an anodised alloy plate.
The new Morel SCM634 midrange driver
In short, these speakers are stunners, especially with the magnetically attached grilles removed and the drivers on show, most notably that impressive Morel SCM634 carbon fibre mid, which is so new that it’s only used by a handful of high-end speaker manufacturers. It’s similar to the bass/mid used in the Petite Performa but it’s a pure midrange, so doesn’t suffer any of the inherent compromises of a driver that needs to reach down into the lower octaves while also handling the vitally important midrange frequencies.
This high-tech driver is made up by layering carbon fibre on either side of a Rohacell layer (a material used to make helicopter blades) – this results in an ultra-stiff cone that’s also self damped. Its roll-off and response characteristics allow Chris to utilise a simple crossover network, which reduces any adverse effects to the bare minimum. This is the top of the range in midrange drivers from Morel and according to Chris, it’s so accurate and revealing that getting the new Paragons ready to go has been the toughest experience he’s had in four decades of speaker manufacturing. Even the tiniest changes in design, materials or component selection made big differences in the sonics, which necessitated a seemingly endless sequence of adjustments and comparative listening sessions before he was willing to show the speakers off to press and public alike.
Listening
The Paragons measure up as being 90dB efficient, so they’ll run reasonably well on only twenty watts of valve amplification but they need some power to really rock at high levels if that’s what the owner wants. On the day, they were driven by $17,000 of MBL 8011s dual-mono solid state power amp, which produces a sturdy 210 watts into an eight ohm load and much more into the four ohm load of the Paragons. The preamplifier was one of Tim de Paravicini’s lovely E.A.R 868 valve units, which is priced at $8,500.
The source was Mark’s backup player, an Audiomeca Obsession II, which is a discontinued model but given that it was priced at approximately $5,000 when new, is still a player to be taken seriously. That said, he did indicate that the source was the weak link in the system. Cable duties were handled by Kubala-Sosna Expression interconnects at around $1,350 per meter and Kubala-Sosna Fascination speaker cables (single wired with jumpers) priced at $1,500 per meter. The speaker cables were lifted off the floor by what I initially took for some ultra-exotic handmade cable supports but these turned out to be nothing more than the boxes from Sake cups – a functional and lovely choice.
Sake box cable lifter
We (Gary Steel and myself) only had a couple of hours with this system and the speakers, so this can’t be considered a full review, rather it’s an overview. It’s not realistic to investigate every aspect of any component’s sonic characteristics in a short session but it is possible to make some valid judgements as to its abilities. We played a wide variety of music and strangely enough, only one of Steel’s music choices sounded like a tuning signal originally used by the British Air Force to set up radar units in 1941.
The first thing that stands out about the sound of the Paragons is the openness and accuracy of the midrange. That driver is something special – I’ve heard the Petite Performa, along with its MASS module and it displays the same characteristics through the midrange but the Paragons take that and run with it. There’s a difference between a sound that’s detailed and one that’s genuinely revealing. When you’re listening to a drum kit and you’re able to clearly distinguish the strike of the stick on the drum skin as a separate musical event to the sound the drum actually generates from that strike, then you’re lucky enough to be in front of a high-end loudspeaker (or inside a set of good headphones). The Paragons do this trick seemingly without effort. (continued on page 2……)
Image Paragon 2 Floorstanding Loudspeakers Overview Our first track was ‘Thru and Thru’ from The Rolling Stones’ Voodoo Lounge CD, which starts off slowly with the guitars before Keith Richard’s voice comes in. The soundstage in the room was both wide and deep, very deep, so the guitars and their reverberance had a huge presence and were hung in space well behind the speakers. The rough vocals prompted the standard hi-fi reviewer’s eyes closed, tilted head listening position as I absorbed more of the track than I’m used to. When the first two loud drum strikes kicked in at just over two minutes, I cracked a grin because they blasted out with power and speed. These strikes keep coming for two more minutes before the song rips into its full glory and at that point, my smile just got wider, while the MacBook Pro got its lid closed so I could concentrate on what I was hearing. My foot had been tapping from the start of the track but now my head started bopping along like a nodding dog on the parcel shelf of a rally car.
Steel’s first track was ‘Birds’ from Emiliana Torrini’s Me and Armini, which starts off as an intimate recording with close miked vocals and a guitar. The Paragons laid bare every aspect of the song, from the slow and exacting way the singer shapes each word to the distinct separation between the sound of fingers on strings, the vibrations of the strings, the actual guitar note and the sound of the guitar body. This song always gets the hairs on the back of my neck standing on end and I don’t think that I need to hand in my man card if I call it beautiful. The more complex second half of the song was carried off with equal aplomb and was just as enjoyable. The low notes that run through the track were present but Steel and I both noted that they didn’t seem as strong as expected. This is the same room that I heard the first version of the Paragons in and I knew that setup here was critical. This is a relatively large pair of big speakers and the placement makes all the difference to the way they interact with the room.
Moving around the room revealed that the Paragons had zero trouble reproducing those low notes, it’s just that the listening position has been chosen according to Mark and Chris’ tastes; sitting a foot or two further back offers a great deal more bass weight and going back further still shows that the Paragons are quite capable of driving a large room like this one, so bank on having both a big room and flexibility in terms of placement if you want to offer these speakers a home.
Rather than trying to eke the last bit of low frequency extension from his speakers, Chris prefers tight, controlled bass, so the Paragons roll off from 40Hz down to an in-room -3db point of 32Hz. It’s preferable to add a capable sub woofer (or two) to fill out the lows if the owner feels it to be absolutely necessary. That said – the low bass sounds spot on given the vagaries of the room; in the right place, there’s more than enough weight without any looseness
We progressed through a number of tracks ranging from the smoothness of Steely Dan’s ‘Hey Nineteen’ to the pulsing electronica of Monolake’s Interstate and the MTV Unplugged version Neil Young’s wistful ‘Look Out for My Love’. At no stage did I feel that any aspect of the sound could be criticised but we hadn’t really turned up the wick on the preamplifier as yet, so on went Blue Man Group’s ‘Drumbone’.
With the volume turned right around to the three o’clock position, the Paragons rocked away, shifting gear from subtle to raucous. The speed and attack were memorable, the bass lines gripping, the levels in the room high and the rhythm infectious. They never for a second hinted at losing control and the high-resolution aspect of the sound was still very much present. The excursions on the bass woofers were remarkably small considering how hard they were working and there was more to come if we wanted it but in that room, any more volume would have been superfluous.
So the Paragons have the ability to punch out big-volume rock as easily as they can place the delicate notes of a female vocalist in the room and make it sound as if she’s right there. This is thanks to their even-handed, neutral and accurate presentation, with seamlessly integrated drivers and not a hint of peaks or suck-outs. Even on tracks with abundant treble energy, there’s no top heaviness, brightness or any sense of long term listening fatigue. That midrange driver offers a great deal of insight into any recording and these musically versatile speakers should partner well with just about any appropriately capable audio components.
Conclusion
This overview is by no means definitive but after even a short session, I’m convinced that the Paragons can match abilities, and looks for that matter, with anything in their price range. A full review would reveal more of their strengths but would be unlikely to highlight any serious weaknesses.
They’re world-class speakers but that should go without saying for any speaker priced at $13,000 dollars. However, like their predecessors and some other excellent pieces of Kiwi made audio gear I’ve heard over the years, these speakers would undoubtedly be priced at a more extravagant level if manufactured and marketed in an overseas market. However, you’d have to drive the price up by a considerable margin before they stopped looking like a good buy.
Could I live with them over the long term? If I had a room big enough to do them justice and electronics that could aspirate them properly, I’d have little hesitation in giving the Image Paragons a very serious audition, even a home for life.
www.imageloudspeakers.com
www.audionut.net
www.fymhifi.com
