JPS KAPTOVATOR电源线,瞬间带你进入全高清世界的顶级动力电源线... [复制链接]
查看: 5832|回复: 7
KAPTOVATOR电源线从外表而言,可以跻身为世界上最漂亮最华丽最土豪金的电源线!
先来看美国JPS官方的说法,我来简单翻译一下
The Kaptovator is one of the most advancedultra-high resolution power cables available. No other cord in theworld utilizes such forward thinking designs incorporatinghigh-tech materials combined with the many subtle details andrefinements that years of experience in making the world's finestlong-term reference cables can bring to yoursystem.
TheKaptovator(以下简称为K)K是一根最先进的超级高解析力的电源线。世界上几乎没有其他线运用如此高科技的材料与理念。K是长时间受欢迎的电源线,挖掘出你的音响系统最丰富的音乐细节。
The Kaptovator starts with a special alloyblend, ultra-fine purity 8 gauge/8.35 mm2 conductor, easily thelargest conductor of any high-end AC cable. This is no ordinaryrun-of-the-mill conductor, and its response optimized, concentriclay coupled with a very tightly twisted design makes for a verycompact and flexible wire that acts as a solid, as one largecoherent conductor for power, greatly improving low frequencydefinition and allowing a clean natural sound with amazingly welldefined bass, yet never sterile nor bright.
K的内部是特殊的合金材质,粗达8.35平方的超高纯度导体,是在HIEND电源线中最粗的。精心设计的结构使得其能够极大提升低频的清晰度,精确的低频带来干净自然的声音,既不粗糙也不过亮。
Where the Kaptovator sets itself apart is withits unique insulation material, which can greatly determine howwell a cord will perform and its final sonic character. JPS Labsfound Kapton® to be an amazingly great insulator forour finest AC cord, and a very expensive one. Kapton is a veryhigh-tech dielectric used mainly in space and military applicationswhere performance means everything and cost is no object. Unlikeall other ac cords, the Kaptovator will not absorb low level detailnor blur information within a thick mass of low grade insulation.Both audio and video components will greatly benefit from theresulting dramatic increase in detail retrieval.
K采用了特殊的屏蔽材料,这对于线材的最终表现有很关键的影响。K采用了Kapton作为绝缘材料,这种材料是极为高科技的绝缘材料,被用于美国的太空与军事领域,众所周知,在这两个领域,成本根本不是考虑的因素,一切以性能优先,由此可见Kapton具有优异的性能。与其他的电源线不同,K不会不会让细小的细节消失,不会让信息混乱,无论视频还是音频都会展现出最清晰的一面。
The Kaptovator's outer jacket is clearfor all to see how neat and orderly the inside of a well designedcord can be; and what you are paying for. Most cord designers wouldnever think of allowing this. As with all of our unique cabledesigns, simplicity proves to be best, and of course what lookssimple is not always as simple as it looks. This special clearouter jacket's elasticity was adjusted to also act as a veryeffective dampening material to address any mechanical vibrationtraveling along the cords length which may affect the cords truesonic character (or lack of it), and special surface coatingsdissipate any static build-up. Many more 'hidden' and costlyfeatures have been included in this unique AC cord's design,including Wattgate gold audiophile grade plug (or gold plated Euroor UK), and so many small details considered nothing short of artin cable design, but of course we must keep some things asecret...
K的外衣故意采用透明材质,为了让大家清晰看到内部的构造,以及你花的钱到底是花在了哪里。绝大多数线材品牌不会这么做。这个透明材质的外衣也不一般,是良好的吸振材料。
The Kaptovator is better at supplyingpower to low power components on up to the largest of amplifiersthan any other cord ,making it a highly universal mate for justabout any component capable of greater resolution at it's output,including tube and digital components.
K不论对于小功率设备还是最大功率的放大器都能表现出色,包括电子管与数码器材。
Low frequency bass definition will improvedramatically with an incredible rolling of bass drum most systemscannot reproduce , and bass guitar and piano strings will resonatewith a full set of overtones intact. Mid and high frequency air andresolution will be at their peak of perfection. Vocals will soundso very real, full and rich, with no hint of brightness orforwardness, in proper perspective. All instruments will be wellfocused and well rounded while keeping their original harmonicstructure intact, just as if they are all right there with you inthe room. It becomes increasingly important with an AC cord such asthis that the rest of your systems' cables and AC cords aretruthful to the source, not tayloring the sound. If you are alreadyusing JPS cables, life will be good.
We guarantee this to be one of the finest powercables money can buy. Please take the time to audition theKaptovator Power Cord in your system- to hear thepossibilities.
K的低频瞬态极快,因此提升了全频段的动态。中频与高频的空气感与解析力达到完美的顶峰。人声听起来非常真实,细节丰富。结像不会向前冲,不会偏亮,在应有的位置上歌唱。所有的乐器定位明确,发出真实的泛音。就像在你的房间里真实的陪伴你。他的好解析力使得其他线与你的器材的特点被忠实反映出来。我们保证,这是钱能买到的最好的电源线之一。
看完官方的介绍,我正式来谈我的使用经验
首先要说的是,这条K电源线是不适合放在音源的位置的。将其接到我的CD机后,开声后,优缺点都非常分明。优点是一瞬间就让我醍醐灌顶的,透明到不能再透明的如水晶一样的透明度,细节夸张无比,从超高音到极低音事无巨细地展现出来,音色明亮而直接。声场巨大,解析力极强。但是,听了一会儿,就感到缺失了最关键的一样东西,就是乐感。在音源,K电源线无法将细节连绵地连接起来,因此,乐感无法连绵流畅,纵然有顶级的透明度与解析力,反而显得过于机械化,听起来很累。可能与其8.3平方的粗线径有关,小功率的音源,我个人认为使用K反而是不合格的。
然而,随后我将这根K用于总线,耳放,合并功放,再生电源,功放,后级,以及前级分体式电源EPS上,得到的结果是肯定的。越是大功率的器材,越是能让K电源线发挥大线径的优势。用在大功率设备上,K的声音就不会出现用在CD机上的死板的现象了。
我是从JPS的PAC LITE升级到AC+,再升级到K的。三者的区别在于,PACLITE中规中矩,最便宜,但是只要你预算不差1000元,肯定建议上AC+。而比PACLITE贵1000多元的AC+具有明显饱满与庞大的声场与丰富的信息量,性价比是三者中最高的,而且音色没有染色。而价格比AC+贵一倍以上的K,则具有一下子甩开AC+的至高透明度,声音的轮廓比AC+鲜明得多,声音的HIFI性大幅领先,从AC+切换到K,仿佛从DVD的清晰度上升到蓝光碟的清晰度,从标清到高清。而且音色上比起AC+的无色,增加了凝聚产生的金色光泽感。但是,过于清晰反而未必是好事情,因为其对声音收的最凝聚最紧,反而在宽松感上倒不如AC+。因此,适合搭配的是偏宽松的器材,而非本来就突出透明度与线条感的器材,这点需要格外注意。
K电源线的声音,用在除音源外的环节,动态干脆鲜明,线条极为清晰凝聚,低频快速没有过多的量感,是清晰度与素质优先的风格。细节与透明度被强劲的能量带出来,声场非常大,而且声音的结像与定位清晰度极高。需要注意的是,他的能量分布并不是中低频极为饱满的风格,因此会有两个注意点,如果你使用K,发现声音偏紧,下盘不够饱满,中高音偏明亮与硬朗,那么说明K未必适合你的系统。在使用上,我认为将K放在后面,前面用柔润细腻的音乐性好的线材进行组合,才是最佳的用法。因为,K不属于好听类型的线,而是属于好素质类型的线,最后面的环节才是其发挥本领的领域。
论坛篇幅关系,关于本线的20多张高清照片详解见博文:http://blog.sina.com.cn/s/blog_40f078a90102eg6m.html
最后编辑sega88 最后编辑于 2014-05-02 22:10:36
狗狗线材的投资比占到多少了?30%?
怎么没看出好
言过其实,唉
原帖由 海-浪 于 2014-5-3 18:48:00 发表
怎么没看出好
声音岂是靠看出来 与 YY的?实际听听最重要。
请说说它的大老aluminata  风格是怎样?谢谢!
古典烧友
插头上标注的规格是15A、125V?
美标wattgate插头当然标注15安125伏
