Perreaux SXV2 Phono有哪位了解的? [复制链接]
查看: 2919|回复: 3
想问下声音表现及市场价格,麻烦咯
jpg(2014/7/17 15:28:20 上传)
SXV2 Phono Preamplifier
Rated Output: 0.75VRMS
Sensitivity:  0.24mV to 7.5mV*
Gain:  40dB to 70dB*
Maximum Output: 7.9VRMS
Input Overload Margin: 20dB
Load Impedance:  10Ω to 47kΩ*
Load Capaitance:  27pF to 417pF*
Total Harmonic Distortion (THD+N)
  Typically:  0.002% @ 1kHz**
  20Hz to 20kHz:  <0.01%**
Signal to Noise Ratio (unweighted):  85dB**
RIAA Equalisation:  IEC or Normal*
RIAA Accuracy: ±0.5dB, 20Hz-20kHz
Output Impedance: 27Ω
Note: *User selectable  **Measurements taken with lowest gain setting
Dimensions:
Width
Height
Depth  216mm (8.5")
58mm (2.3")
168mm (6.6")
Weight: 1.5kg (3.3lb)
新西兰的牌子,音色比较温暖。
台湾telos代理这个牌子,国内不知道谁代理。
