返回列表 12345678» / 15
2015,从Classic Boy开始…… [复制链接]
查看: 67136|回复: 142
H1520-08 U16RCY/P
U16RCY/P is a 5” High Fidelity woofer with an injection moulded
metal chassis, intended for bass reflex and transmission line designs.
New Curv cone, a woven polypropylene with excellent internal damping together with perfectly matched moving parts gives a smooth, extended frequency response.
A unique radial reinforced low loss rubber surround reduces radial resonances and prevents surround break up at large excursions.
Bullet shaped phase plug reduces compression due to temperature variations in the voice coil, avoids resonance problems which would occur in the volume between the dust cap and the pole piece and increases the long term power handling capacity.
Extremely stiff and stable injection moulded metal basket, keeps the critical components in perfect alignment. Large windows in the basket both above and below the spider reduce sound reflection,
air flow noise and cavity resonance to a minimum.
This driver uses Seas SpiderRing® technology.
Frequency response
The frequency responses above show measured free field sound pressure in 0, 30, and 60 degrees angle using a 28L closed box. Input 2.83 Vrms, microphone distance 0.5m, normalized to SPL 1m.The dotted line is a calculated response in infinite baffle based on the parameters given for this specific driver. The impedance is measured in free air without baffle using a 2V sine signal.
Specifications
*IEC 268-5 SEAS reserves the right to change technical data
E0006-06 T25CF001
The T25CF001 is a 25mm fabric dome with moderately high efficiency.
An optimally shaped dome and a wide SONOMEX surround, both manufactured by
SEAS, ensure excellent performance and consistency.
Low viscosity magnetic fluid which provides excellent cooling while maintaining a low resonance frequency.
6 mm solid metal front plate with a slight loading characteristic which ensures
linear frequency response, and a stiff and stable connection to the cabinet.
A substantial injection-moulded rear chamber, with complex internal shape and
reinforcing ribs, which eliminate unwanted chamber resonances and reflections.
A double magnet system which increases sensitivity and provides better control of the voice coil.
This system also reduces the magnetic stray fields, making the T25CF001 an ideal choice in high end A/V applications.
Frequency response
The frequency responses above show measured free field sound pressure in 0, 30, and 60 degrees, mounted in a 0.6m by 0.8m baffle. Input 2.83 Vrms, microphone distance 0.5m, normalized to SPL 1m. The impedance is measured without baffle using a 2V sine signal.
Specifications
*IEC 268-5, via High Pass Butterworth Filter 2500Hz 12 dB/oct. SEAS reserves the right to change technical data.
3L-Audio Studio, established since 1993, has been dedicated to Hi-Fi audio R&D for over 20 years.
CLASSIC BOY TOWER
CLASSIC BOY TOWER
看上去很不错
这个H1520比铝盘的H1488 靓仔,更亲这个木皮箱体。
