CODA41.0立体声后级 [复制链接]
查看: 4453|回复: 1
(2021/10/29 16:37:39 上传)
www.fymhifi.com
输出功率:400瓦x2(8欧),800瓦x2(4欧)
瞬态电流:100A
电容:28万微法
变压器:3000kw
频率响应C to -3dB @ 100kHz
增益:26dB
失真:< .02 percent from 10Hz to 20kHz @ rated power
信噪比:-120dB referenced to rated output
输入阻抗:50k Ohms unbalanced/10k Ohms balanced
输出阻抗:.03 Ohms from 20Hz to 20kHz
体积:480x440x19mm
重量:50kg
www.fymhifi.com
