数码信号线的差别? [复制链接]
查看: 3916|回复: 4
想请问大家:
数码线用光纤或同轴的差别是否很大?不同级数的线之间呢?理论上觉的不应该,但...?
理论上是同轴好些,但我感觉不到!
一般来说,应该高端器材中用同轴好点吧。。。
当然,同轴线本身的品质也要保证,,,据闻,用75欧BNC头就比RCA的要好,,,不过我的器材是测不出来的。
在网上找到这一段:
Jitter can be measured with sophisticated oscilloscopes and then the value computed in picoseconds (ps). The higher the ps value, the worse the jitter caused by that particular medium. Some examples of measurable jitter from different digital interconnects used in Hi-Fi : Optical (plastic) cable – 2944 ps, Electrical (co-axial) cable – 1434 ps. * taken from Monarchy Audio’s site * As you can see, the difference between two standards of digital transmission and the medium used can cause as much as a 50% difference in jitter.
所以大侠们普片认为,同轴比AT&T石英光纤好,AT&T石英光纤比TosLink好。我还没机会试。
重起 在 2004-3-13 19:18:45 发表的内容
在网上找到这一段:
There are other issues such as the quality of the coaxial and fiber optics.
Coaxial counts of the quality of the conductor but most important is the
impedance of the cable and the terminal.
The impedance of the cable would affect the jitter but most of the
terminal such as BNC, they heavily count on the impedance. Some of the
BNC doesn't have accurate impedance that cause standing wave and
eventually jitter increase.
On the other hand, fiber optic counts on mainly the quality of the material
used. Plastic of course has many quality level but the best yet is glass
optic that seldom see on audio market.
