返回列表 12345678» / 13
最近动力水之类垃圾又甚嚣尘上,翻老帖子打鬼! [复制链接]
查看: 26228|回复: 129
最近HIFI乐趣区出现了一些莫名其妙的贴子,宣传什么动力水、魔法戒指、神油之类,引发很多争论。但明眼人一眼就可看出其中有JS和众多马甲在背后动作。本人玩音响有7年,所幸还没烧坏脑子,觉得有必要把这件事提上论坛讨论,大家集思广益!
1、HIFI乐趣应不应该有这样的明显的商业贴?许多BBS是严禁在非买卖论坛出现宣传产品贴的?
2、这些我认为是伪发烧的东西对于玩音响,到底是有益还是有害?我们是不是应该把精力放更多到电路、原件、喇叭、搭配、线材上,而不是这些放着离喇叭3米远就能改善音质,或涂抹在碟片上,就能让数字视频更上一层楼的玄妙东东上?
为慎重起见,建议大家看完这个帖子,看完大家提出的论据和论述和引证,再作选择。
投满100个人,这贴作用就达到了,贴子去留随版主吧。
投票:最近动力水之类垃圾又甚嚣尘上,翻老帖子打鬼! - 截止时间:2026/11/8 8:21:45
抱歉,您所在的用户组没有参与投票的权限,请注册或登录!
最后编辑ppzz
大人要懂得用经验来判断事物,而不是什么事都要试一遍,有这种心理,才使JS有那么大的生存余地。
看不过眼 在 2004-8-4 22:22:07 发表的内容
我又刚投了赞成票, 怎样?
老兄投那么多赞成票干什么?
---------明白了,是搞破坏。
看来这个投票还真是让JS们寝食难安了。
---------高兴!!!
闲来无事,把古河主页上的企业介绍拷贝下来评点一下,在座的英文高手肯定众多,不知可曾仔细看过。
FURUTECH Company is established in (这里少一个冠词)year of 1988. In the beginning, he(男他,好生动阿,阳刚之美) was famous throughout all of worlds by(应该是for) selling all kinds of Furukawa Electronic PCOCC Audio & Visual cables (high purity single crystal oxygen-free copper used for Audio & Visual cable), also have earned confidence and support from a vast of Audio & Visual funs(应该是fans).
By accumulated many years experience of successful sales(完全的中国英语) various of audio & visual cables, well familiar with the loss of transmission single between Audio & Visual accessories and cables. is so astonishing. The perfect single transmission is no more traditional industrial grade or even hospital grade accessories can be satisfied Firstly, will promote the important concept of Audio Grade accessories, even promote the whole series Hi-end grade’s high quality accessories products.
Our products are included(被动?) all kinds of Home Audio & Visual cable, power Tap ( RTP-6), Power Filter ( e-TP60. e-TP80), Disc Demagnetizer ( RD-2), Tuning panel ( RWL-1), Disc pure cleaner ( PC-2)., 3C surface treatment liquid , all kind of Audio Grade/Hi-End Grade accessories, various cables and Audio Grade Accessories for Car Audio.
FURUTECH PURE TRANSMISSION--- CONCEPT
FURUTECH products research and development department is specialized in research material(反了?), technology of creating(manufacture?) cable, precision process way and constantly conducts the top pointed scientific technology. To research and development(develop?) super top pointed technology (super+top?) as our ideal, adhere thoroughly spirit of research and development, to realize (the?) FURUTECH “Pure Transmission” concept.
我又刚投了赞成票, 怎样?
老兄投那么多赞成票干什么?
---------明白了,是搞破坏。
看来这个投票还真是让JS们寝食难安了。
---------高兴!!!
不是盲听作不得数的。
对了,向海阳兄问个问题:
如果音箱下面垫大理石,两层中间夹软垫。那么上层大理石可不可以看成音箱的一部分?下层大理石可不可以看成是地板的一部分?这样是不是就相当于加重的音箱垫了软垫?那音箱的脚钉还有什么用处呢?
音箱基座的出发点是什么?是不是应该尽可能坚实不振动?那么垫软垫岂不是会增加共振?如果软的阻尼更好,那音箱干嘛不用橡皮的脚钉?
我自己的音箱是金属脚钉落在玻化砖上的。试过直接橡胶垫不好。
转
[upload=jpg]Upload/200483148360268.jpg[/upload]
CD Stop Light 實 試 報 告
CD STOP LIGHT 本 文 簡 稱 綠 筆 。
它 的 用 法 是 塗 在 CD 碟 的 外 圍 和 接 近 中 央 圓 洞 的 凹 環 ( 有 些 CD 沒 有 這 個 凹 環 ﹐ 這 個 凹 位 並 不 等 於 中 央 圓 洞 的 內 環 ! ) 。
CD 綠 筆 的 作 用 ﹐ 是 將 CD 運 作 時 雷 射 光 束 的 散 射 ( diffusion ) 減 到 最 低 。 其 實 一 部 CD 機 在 運 作 時 ﹐ 由 於 設 計 上 要 盡 量 讀 取 多 種 不 同 金 屬 壓 製 的 碟 片 。 雷 射 光 束 的 光 度 會 相 當 地 強 ﹐ 亦 因 碟 面 在 實 際 應 用 上 不 可 能 理 想 地 與 光 束 作 180 度 接 觸 ﹐ 因 而 產 生 相 當 多 的 光 束 散 射 ﹐ 這 些 散 射 光 會 不 停 地 影 響 到 讀 取 的 資 料 ﹐ 間 接 地 觸 動 CD 的 改 錯 系 統 啟 動 ﹐ 影 響 讀 取 資 料 的 準 確 度 ( 音 質 ) 。
[upload=jpg]Upload/2004831482853100.jpg[/upload]
錄 筆 是 由 美 國 音 響 專 家 William Rasnake ( 即 別 名 摩 王 Bill ) 發 明 的 。 他 於 聆 聽 CD 時 發 覺 ﹐ 碟 面 上 的 顏 色 會 對 音 色 有 不 同 影 響 ﹐ 而 經 多 個 試 驗 後 ﹐ 發 覺 綠 色 最 能 忠 實 地 重 現 原 音 ﹐ 於 是 製 造 了 這 樣 產 品 並 取 得 美 國 專 利 。
由 於 該 種 綠 色 是 特 別 配 製 的 ﹐ 效 果 當 然 是 最 好 的 。 但 其 實 也 可 以 用 普 通 綠 色 油 性 MARKER 筆 代 替 ﹐ 當 然 要 視 乎 那 隻 碟 的 錄 音 去 調 節 份 量 啦 !
通 常 播 放 時 像 蓋 上 了 厚 布 或 音 樂 細 緻 地 方 聽 不 清 楚 的 錄 音 才 要 全 隻 碟 的 邊 緣 都 塗 上 ﹐ 其 它 錄 音 不 錯 的 CD 只 塗 內 環 或 將 外 環 梅 花 間 竹 式 塗 上 便 可 以 了 。 這 產 品 是 水 溶 性 的 ﹐ 塗 出 界 用 水 擦 掉 便 可 以 。
[upload=jpg]Upload/2004831484890344.jpg[/upload]
我的看法是不要轻易相信,小心谨慎.没试过听过,道听途说就下结论.
我不支持,我用的美国的消磁剂.连我老婆都听出很大的区别,我根本不去管他是什么科学原理.我现在用光了,到处找也买不到!
顺便看看论坛musicone老兄对其评价:光碟动力水这个DD效果确实不错。试用后看《史前巨鳄》,高度还原清晰逼真的画面,当主角落在水里慌忙地寻找那巨鳄时,巨鳄在他身后静悄悄地浮出水面那一刻,那宁静的气息和惊心动魄的场面······
顺带说一句,对这位老兄我稍微注意了一下,发现了一些很有趣的事情。MUSICONE老兄和富昌兄均注册于2004年5月11日,两个IP61.144.114.32和219.137.38.193尽管貌似不同,但都是来自广东省广州市,都是电信的ADSL。
纯属巧合别无他意阿。
