发份升压牛的资料给玩LP的朋友看看 [复制链接]
查看: 2202|回复: 2
What step-up for my cartridge?
This is THE question. If you’re looking for a step-up you can buy second hand step-up transformers, brand new (most Mc cartridge manufacturers produce step-up transformers) or build them yourself using parts from manufacturers like Lundhal, Sowtek, Hashimoto, Jensen.. (See links to those manufacturers at the end of this paper).
To make things clearer, we’re going to take a look at the specifications of available products. Why? Because these products were designed by MC manufacturers, let’s assume that they knew what they where doing.  Specs shown here are compiled from various sources (internet or vinylengine inmates like Yosh (Hi Yosh!). if you have data relating to other products, contact me and I’ll add them to the table. All I need to know is the gain (measured in db or in amplification factor 1)  and the recommended internal impedance of the cartridges to use with that step-up.
Data in bold type are manufacturers specs, other data was recalculated this way:
X factor = 10^[(gain in db)/20]
Gain in db = 20*ln(x factor)/ln(10)
Natural impedance = 47000/[(x factor)^2]
Manufacturer    Model    Gain in db    x factor    Natural impedance    Recommended Impedance
Ortofon    T5    26    20,0    118,1    3-40 ohms
    T10    32    39,8    29,7    2-4 ohms
    T10 MK2    28    25,1    74,5    2-6 ohms
    T20    32    39,8    29,7    2-4 ohms
    T20MKII    28    25,1    74,5    2-6 ohms
    T30    20    10,0    470,0    24-48 ohms*
         29    28,2    59,2    6-12 ohms*
         32    39,8    29,7    5
    SPU-T100    26    20,0    118,1    1-6 ohms
    T1000    26    20,0    118,1    2-6 ohms
    T2000    35    56,2    14,9    3
    T3000    30    31,6    47,0    2-10 ohms
Fidelity Research    FRT-4    31    35,5    37,3    3
         26    20,0    118,1    10
         25    17,8    148,6    30
         20    10,0    470,0    100
    FR XF-1    30    31,6    47,0    4-18 ohms
    FRT-3    26    20,0    118,1    30
         31    35,5    37,3    10
    XG5    34    50,1    18,7    < 3 ohms
         26    20,0    118,1    3-18 ohms
         22    12,6    296,5    18-40
    X1-M    30    31,6    47,0    4-18 ohms
    X1-H    25    17,8    148,6    19-40 ohms
    X1-L    36    63,1    11,8    3
Denon    AU 320    31,1    36    36    3
         20,0    10    470    40
    AU 340    30,4    33    43    3
         20,0    10    470    40
    AU310    20,0    10    470    40
    AUS1    22,3    13    278    3-40 ohms
    AU300LC    20,0    10    470    40
Audio Technica    AT700T    34    50,1    18,7    3
         26    20,0    118,1    20
         23    14,1    235,6    40
EAR    MC4    29,5    30    52,2    3
         27,6    24    81,6    6
         25,1    18    145,1    12
         20,0    10    470,0    40
    MC3    29,5    30    52    4
         26,0    20    118    12
         20,0    10    470    40
Supex    SDT 3300    28,5    26,6    66,4    2-10 ohms
Bryston    TF1    22,5    13,3    264,3    5-35 ohms
         16,5    6,7    1052,2    40-250 ohms
Rothwell    rothwell    22,0    12,6    296,5    100
Nakamichi    MCB100    26,0    20    117,5    2-20 ohms
Sony    HA-T110    26    20    117,5    3 - 40 ohms
麻烦了,图表贴上后错位了
最后编辑recorders
还是不行
最后编辑recorders
