有人知道德国的AVM的V2/M2前后级amp吗? [复制链接]
查看: 7819|回复: 29
有人知道德国AVM的V2/M2前后级amp吗?
国内有代理吗?不知道大概什么价位?
好多地方说用来推audio phisy的落地箱virgo III效果很不错。
不知道搭配elac的箱子如何?ELAC 310 或者330可以吗?
M2:
http://www.avm-audio.com/en/products/m2.html
AVM evolution M 2
Technical highlights eveolution AVM evolution M 2 in bullets
extremely short signal paths for quick reaction. Rise- / fall times below 1 microsecond
RCA-cinch inputs as well as balanced XLR inputs. Fully insulated speaker terminals. All gold plated
PC-boards almost using SMD technique
two independent power supplies for driver and power stages make the circuits free of influences from load. drive capability down to 1 Ohm load.
soft start circuitry avoids large current peaks when switching on.
a 300 VA power transformer, over 35.000 microfarads of capacitance, extremely fast rectifiers make a stable, quick power supply with huge reserves for powerful bass reproduction
protection circuitry against DC, overheat and short circuit ensure trouble free operation
automatic switch on and switch off circuitry makes the mono amps easy to use
environment friendly 3 watts stand by power consumption
cases available in black, aluminum (silver). Front panels in black and silver aluminum or polished chrome
Technical data AVM evolution M 2
sensitivity RCA cinch:  1,1 Volts/5 kOhms (270 W / 4Ohms)
sensitivity balanced XLR:  1,1 Volts/10 kOhms (270W / 4Ohms)
power output in 8 Ohms:  160 Watts
power output in 4 Ohms:  270 Watts
power output in 2 Ohms:  380 Watts
intermodulation 25 W/4 Ohms:  < 0,01 %
THD 25 W/4 Ohms:  < 0,005 %
transient intermodulation (TIM):  not measurable
S/N ratio 25 W/4 Ohms:  > 100 dB (A)
frequency response:  < 0,3 Hz - >400 kHz
load bandwidth 25 W/4 Ohm:  < 0,3 Hz - > 400 kHz
rise time into 4 Ohms:  < 1 µs
damping factor:  > 500 (1 kHz)
power supply:  AC 230 Volts / 50 Hz / 300 VA (standby 3 VA)
dimensions (W x H x D):  210 mm x 105 mm x 285 mm
weight:  8 - 11 kg
V2:
http://www.avm-audio.com/en/products/v2.html
AVM evolution V 2
Technical highlights AVM evolution V 2 in bullets
toroidal transformer with reduced stray field, over 10.000 microfarads of capacitance, extremely fast rectifiers
signal path totally DC coupled (except phono)
1 balanced XLR input, 6 RCA cinch inputs
low impedant output stages in class-A technique
1 tape monitor, 1 processor in- / output
parametric loudness, bass boost, bass and treble controls (can be switched off)
phono MM or MC input (option)
all functions can be remote controlled (IR transmitter (option) necessary)
environment friendly 1 watt stand by power consumption
Technical data AVM evolution V 2
sensitivity
line: 18 - 180 mV
MM: 0,18 - 1,8 mV
MC: 0,03 - 0,3 mV
input impedance
line bal. XLR: 10 kOhms
line RCA cinch.: 33 kOhms
MM: 47 kOhms
MC: 1 kOhm
S/N ratio
CD: 103 dB(A)
MM: 89 dB(A)
MC: 75 dB(A)
frequency response
line: 1 Hz - over 1 MHz
phono: 30 Hz - over 20 kHz
rise time: 0,43 µs
outputs
impedance RCA cinch: 50 Ohms
impedance bal. XLR: 150 Ohms
max output voltage: over 6 V
power consumption
ON: 12 W
Stand by: 1 W
power supply:  230 V / 50 Hz / 15 VA
dimensions:  435 x 80 x 320 mm
weight:  6 - 8 kg
ding~~~
没有人知道吗?
smert兄??
DING~~~
没人知道吗》?
ding~~
[upload=jpg]Upload/200471318224677928.jpg[/upload][upload=jpg]Upload/200471318235560836.jpg[/upload]
好靓仔,又带有唱放,我都想知道,但德国声好吗?
德国声当然好
就和德国人办事风格一样,经准,快速,动态大
AVM的中港代理是胡须佬ANDY(安美公司)
http://www.anmprom.com.hk/
用过AVM早期型号前后级推我的ELAC 215---4PI II音箱,声音是比较典型的德国声.匹配上一点问题也没有.
请问avm V2/M2是否能推好kef reference系列的205呢?
audionet art v2 的CD 一般什么价位?2。2W左右搞得定吗?
如果用LINN 的IKEMI 或者MERRIDAN 58   三种里面哪一个更合适?
