MIRAGE怎样? [复制链接]
查看: 3708|回复: 8
用人说是可以兼容HIFI和AV的,没听过,请各位大侠评价一下
Mirage是加拿大的一个品牌。我听过其Omni系列的Omni 50和Omni 250,这个系列主要的特点是用到其Omnipolar技术,使声音可以360度方向传播,这样产生的更多的反射声可以获得更真实的听音效果。
Omni系列是蛮好推的,50用NAD 320Bee就可以推的很响了,声音的特点是全频都很松弛,是比较暖的音色,而这个Omnipolar会造成定位不是很清晰的问题,不过音场,特别是左右音场的范围则大了很多。至于其他的我不知道你想了解什么。
广州有,在陶街看过
用CAYIN A88T满不错的,我比较喜欢,定位必须要在大的空间才能处理好.
最后编辑leslie
AV估计是很爽的~~~
hifi如果对付流行歌也好。
问题是广州没有的听,这点教郁闷~~~
MIRAGE250都多同价位里面的高手了。
很适合影院的一个牌子,低频和动态很好,声音密度也不错。和能量是双胞胎
谢谢各位。
各位所了解的只是MIRAGE的低端产品~
MIRAGE也有很出名的HI-FI喇叭,如过去的旗舰M-1以及前几年在国外炙手可热的小型书架监听喇叭MRM-1等~
他们的高端OM SERIES国内比较少见,声音在同价位中是相当不错的..
- Mirage's new high-end flagship series. Information will be posted on our website by the end of October.
OM Design is a new line of ultra-performance speakers from Mirage. The OMD-28 floorstander (left, $3750 each), OMD-R surround speaker ($1000 each)...
...and OMD-CC center-channel speaker all use carbon-fiber midrange drivers and woofers, which have a greater stiffness-to-weight ratio than cones of other materials Mirage tested. The OMD-28 and OMD-CC use Mirage's Omniguide technology to produce 360-degree dispersion.
A close-up of the OMD-28's Omniguide module, which consists of a carbon-fiber midrange, Pure Titanium Deposit Hybrid tweeter and "dispersion saucer." The OMD-28 is the most expensive speaker Mirage has sold. [www.miragepseakers.com]
最后编辑mackiel
各位所了解的只是MIRAGE的低端产品~ MIRAGE也有很出名的HI-FI喇叭,如过去的旗舰M-1以及前几年在国外炙手可热的小型书架监听喇叭MRM-1等~ 他们的高端OM SERIES国内比较少见,声音在同价位中是相当不错的.. - Mirage's new high-end flagship series. Information will be posted on our website by the end of October. OM Design is a new line of ultra-performance speakers from Mirage. The OMD-28 floorstander (left, $3750 each), OMD-R surround speaker ($1000 each)... ...and OMD-CC center-channel speaker all use carbon-fiber midrange drivers and woofers, which have a greater stiffness-to-weight ratio than cones of other materials Mirage tested. The OMD-28 and OMD-CC use Mirage's Omniguide technology to produce 360-degree dispersion. A close-up of the OMD-28's Omniguide module, which consists of a carbon-fiber midrange, Pure Titanium Deposit Hybrid tweeter and "dispersion saucer." The OMD-28 is the most expensive speaker Mirage has sold. [www.miragepseakers.com]
